Results 11 to 20 of 33
Thread: Too low?
    Mar 2012
    Central Coast, NSW
    Mk3 should run a 195/50/15 or similar. Sounds like you have mk4 spec wheels on
    Yeah mk4 sized rubber..
    205/55/15 or 205/50/15 for a mk3 vr?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Mar 2014
    Bundoora, Victoria
    I do have mk4 spec wheels on, I know this. Not sure if this is possible or a stupid question but can I use the tires from the stock wheels (the mk3 BBS wheels)?
    Past - '95 VW Golf MK3 VR6
    Mar 2012
    Central Coast, NSW
    yeah if both 15s that'll be fine but your current tyres are too big
    Aug 2006
    Melbourne VIC
    Roll guards and fit 205/50/15
    Mar 2014
    Bundoora, Victoria
    They say pictures are a thousand words so here's one. The thing is, I couldn't really find where the wheels were rubbing but it did sound like they were so maybe it's actually the springs that are bad? I know that if I press into the car on the rear right the spring creaks. Was like this from the start.
    Attached Thumbnails Attached Thumbnails Too low?-image-jpg
    Jun 2011
    Id say the top of tyre was hitting body.
    As said above. Your tyre sizes are to big, even for factory mk3.
    Mar 2014
    Bundoora, Victoria
    But no marks seems a bit strange, wouldn't there be visible marks?
    Jun 2008
    melbourne
    Take the wheel off and you'll get a better idea if it's rubbing?
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
    Mar 2012
    Central Coast, NSW
    It's probably the tread of your tyre inside the wheel well. Not the guard on sidewall. As stated if you take the wheel off you might see something. M
