Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 106
Thread: Tim's 3 Door VR6 Turbo Build
  1. #31
    Jun 2011
    You said fast.. rest are all broken
  2. #32
    Jan 2011
    Rooty Hill, Sydney
    Broken!
    I said fat ass though, as in they weigh to much
  3. #33
    Apr 2011
    Okay so got a bit of work done today.
    New rear main seal:
    Flywheel on and torqued:
    Clutchnet stage 4 disc and pressure plate:
    New water pump:
    Deleted A/C and installed new accessory belt:
    Thermostat housing fitted:
    Cleaned the oil filter housing it's nice and clean now inside:
    Exhaust gasket installed with new hardware:
    Also added the turbo oil return line and welded some 3mm plate to the sump bottom for scrape protection then fitted it.
    Next step is to install the intake manifold and gearbox.
    Tim.
  4. #34
    Apr 2011
    Quote Originally Posted by cliftronix View Post
    Are you going to run the pumps sequentially or full ball all the time? That is some flow
    I'll be running a return line to the surge tank so should run both at the same time and whatever fuel isn't required will be sent back from the fuel rail to the tank.
  5. #35
    Apr 2011
    Got the Mig Fab short runner intake installed with billet fuel rail as well as 10mm ignition leads. Starting to look the goods now:
  6. #36
    Jun 2011
    You'll need to massage the inside of the gearbox to clearance the rivets on the pressure plate.
    I used a flapper wheel on a 4" grinder.
    Suggest getting a pinion brace too.
    Looks the goods
  7. #37
    Apr 2010
    **** this motor is looking amazing! dibs first ride along when its done!
  8. #38
    Mar 2011
    Inner West, NSW
    Keen for screamer pipe
  9. #39
    Apr 2011
    Looks the goods
    Thanks Hayden I'll see if it spins a full rotation when the gearbox goes and if not I'll give it a grind to get it to fit!
    Already have a pinion brace I'll put it on soon once the gearbox is ready to go on
    Quote Originally Posted by browndizzle View Post
    Haha thanks Simon it's getting there!
    Quote Originally Posted by drucejnr View Post
    Screamer maybe after it's engineered and road worthy haha
  10. #40
    Apr 2011
    Installed a TiAL MV-S 38mm V-Band external wastegate:
    I think I'll set the springs to 1.5 or 2 bar pressure resistance depending on what peak boost pressure is decided upon.
