Good stuff Tim! Know that motor has been in the works for a while! Keen to see it come together now.
This thing is bananas
good to see my engine going to good use!
so excited to see this thing hammer!!
goodluck tim! always here if ya need a hand
The turbo will hit the brake booster . Also the turbo intake will be right next to the brake fluid reservoir .
Bug_racer supports the rebellion of the euro revolution
Thanks guys it will be bananas hopefully haha.
Thanks Simon I'll let you know if I do. The engine was in immaculate condition so it will make a perfect base for it.
Thanks Seb I'm aware of the brake fluid reservoir issue and it will be sorted. As for the charge pipe the compressor housing needs to be rotated and moved and will face towards the P/S anyway, I simply put that photo up for illustration of progress thus far.
How's your VR6 turbo drag car going any more progress from when I saw it a couple years ago?
This is going to be mental
Did you go with a t3 or t4 turbo flange?
Sent from my HTC_PN071 using Tapatalk
