Results 1 to 10 of 12
Thread: Timing Problem
    Aug 2006
    Melbourne VIC
    Question Timing Problem
    Ahhhhhhhhhhhhh
    Jsut put my cyclinder head back on etc filled here up with coolant ($34 worth of g12) and my car sounds like **** under acceleration. I only drove it 200m up the road and though gee that doesnt sound right.
    Got back in the garage put a timing light on and its seems at least 5 degrees advanced Is this normal?
    It could just be me and im a little hesistant but im unsure. Car is heaps more quiet than before due to no head problems.
    What do people reckon?
    Just checking with you guys before Dad gets home.
    Camden, Sydney
    Is it pinging? Clattering noise? Id advance it till it pings then back off a bit. You could have adjusted the dissy timing when you took the head off.
    Aug 2006
    Melbourne VIC
    Yeah it is pinging. When I accelerate it doesnt want to go...
    As you siad I think I may have moved the dizzy and up set it a little
    Im going to sort it out tommorrow with Dad
    Camden, Sydney
    Loosten the dissy and turn it to the right mate
    Aug 2006
    Melbourne VIC
    OK as thought and recommended by Loon the timing was out on the dissy. Took me a while to get the bolt loose on the base of the dissy due to all the crap in the way of my 13mm ring spanner. Gave it some tweakage sounded heaps better.
    To double check put a timing light on and much better
    Down side my car is so much quieter whilst ideling
    Jun 2007
    Eastern Suburbs Melbourne
    but think of all the killer wasps you gained! haha
    well done on doing all this by yourself too mate.
    i like volkswagens
    Aug 2007
    There is a trick to keepoing the timing right when the belt has been off for future reference. On the Aux pulley that drives your oil pump and dissy mark it and the block. When you go to put the belt on turn the aux pulley a tooth to the right and fit the belt, pull the belt up onto the camshaft pulley and when doing so you are putting tension on the long side of the belt which in turn will turn your aux pulley till the marks line up. This way the dissy is exactly where it was and all the slack is on the tensioner side, tension it up and you are done. Never fails. Remember some of the later engines the dis is locked with a pin and you cant turn it , so i would use this method regardless. Have seen many a cherry red exhaust due to wrong timing.
    Jmac
    Alba European
    Aug 2006
    Melbourne VIC
    Jmac that makes so much sense...
    BTW this is my first head gasket iv done all by myself so im pretty chuffed
    Aug 2006
    Melbourne VIC
    I do actually think iv gained some power it revs harder in the garage
    BTW ill be over at yours later we may have to go on a mission from the VW gods
    Feb 2009
    Quote Originally Posted by Water Boy View Post
    ROFL... that's awesome. well done...
