Originally Posted by
Rob Burns
I understand that but the original post doesn't have enough information about why the poster wants to change the chain and reads (to me) as if the poster has been told the chain is a maintenance item. Every post after that seems to just assume that the car needs the timing chain replaced when that might not be the case. I just wanted to make the poster aware of that before they went and shelled out/budgeted for $2k for something that might not need doing after all.
I think everyone here has a lack of understanding how the chains/guides etc work .
The guides should last 400,000km before they wear out , the chains never break , they stretch a little but you have hydraulic dampaners that keep it at a proper tension . Why do you need to replace the chains ? Well , the top chain is pushed by a bolt that has a spring in it . It works via hydraulic pressure from the oil system . What happens is over time or more so with lack of oil changes the pin inside the bolt gets clogged with old oil thats turned crusty , it eventually jams itself and pushes upon the top guide with more force than usual , the chain in turn is pushed against the guide harder and starts cutting into the guides , eventually breaking the rivets at the top of the guide followed by the bottom then it falls apart and starts running rough , occassionaly jumping teeth .
The biggest problem with doing the chains is the headgasket . Made of composite it just falls apart when you pull the covers off . Getting it back together without oil leaks is a hit and miss . One of the reasons why VW went with multi layered metal gaskets on the later VR6's
Bug_racer supports the rebellion of the euro revolution
