I'm sure more experienced guys on here will have their say but I have seen/ heard of quotes from anywhere between 1500-4500 (4500 from austral up here in brisbane, total bunch of wankers).
If you get someone experienced and competent with the cars (ala. Jmac up here in briso) they can drop the gearboxes/ engines out significantly quicker than anyone else and this makes the labour cheaper. But obviously they're the guys always booked out because everyone knows they do the best job and fairest priced job.
I guess it depends whether you're urgently wanting them done/ impatient, or can hang around and wait for someone who knows the cars back to front. Either way it is an extensive process and usually involves removing the gearbox and engine unless you're game to check the timing with the engine in the car. So once you do that there are a heap of other jobs like clutches, input shaft seals, crack pipes, water pumps etc that you may as well do at the same time to save on labor.
I'd be budgeting for $2500 at least and that would provide you with a really reliable VR6 engine good till 300,000... or $1800 if you just want to do the chains.
Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
