u running a 1Z or AAZ mate will need tool for the camshaft ( slot at the back) and ther eis a proper tool for the pump, and a trick when tensioning up the belt and pushing on the pump pin, the tools are readily available on ebay mate. Water pump not timing belt driven but good to change it anyway whilst you spending the time on it, oh and a tappet cover gasket as you need to remove it to line the timing up. Also a good idea to remove the auto tensioner arm for your serpentine belt and give it a good clean and lub
Jmac
Alba European
