Page 14 of 17 FirstFirst ... 41213141516 ... LastLast
Results 131 to 140 of 165
Thread: Thread that combines all my car threads
  1. #131
    Feb 2008
    mOOROOLBARK
    Quote Originally Posted by V666 View Post
    awesome bit of work there, looks like the 6 hours was worth it!!!
    cheers man should find out by the wk end
  2. #132
    Mernda, VIC
    give us a shout over the weekend Ill come over and see it. Might need your help soon to get this engine out!!
    96 Audi Cabriolet : a.k.a THE MANBROLET
    06 Golf GTI : GIAC stage 2, FORGE twintercooler, 3" SPM downpipe and exhaust, hpfp
    99 Audi A6 :The White whale
  3. #133
    Feb 2008
    mOOROOLBARK
    no worries i have tools!!
    im moving out this wk end though, goin to the misses parents house to save more money
  4. #134
    Feb 2008
    mOOROOLBARK
    i got bored at work so i decided i would delete my MAF housing
  5. #135
    Dec 2007
    Ermington, Sydney
    You can do that?
    I'm so doing that...Pete, can you make me one?
  6. #136
    Sep 2006
    Australia?
    Good stuff Pete, I am looking at doing that for my mk3.
  7. #137
    Feb 2008
    mOOROOLBARK
    now that my maf is further away from the throttle body it seems to run a bit richer and has a lower idle
    anyone care to explain why???
  8. #138
    Dec 2007
    Ermington, Sydney
    Pete it looks like the maf sits further out of the centre of the pipe than it should (reading air flow, hence best to put it directly in line?)...that could explain things maybe?
  9. #139
    Feb 2008
    mOOROOLBARK
    Quote Originally Posted by Mrk_Mickey View Post
    thanks dude but its definatly centered or the same as i measured everything to match up
    its not really a problem its actually gives me a bit more punch just wondering why technically?
    if anyone has any knowledge on how a MAF works chime in.
  10. #140
    Sep 2007
    a mass airflow meter works by heating up a thin metallic wire to quite a high temperature. The difference in voltage potential across the wire is measured as a rate of change as the air flowing through the inlet is used to determine what mass of air is passing through the cross sectional area.
    basically. wire gets hot. air going in cools it down. as the hot wire gets colder, the voltage of the sensor changes --> change in mass of air.
    The grid and shape are really all quite important for the maf to work within factory parameters
    87' MK2 GTI
    13' MK7 TDI
