Page 9 of 17 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 165
Thread: Thread that combines all my car threads
  1. #81
    Dec 2008
    Liverpool NSW
    pete, correct me if i am wrong but cams with longer duration be it with a short mani or not need high rpm to give full potential of what these cams have to offer 5000+rpm, now considering you have a 3.94 r&p means you dont have the stock tall gearing to make total use of these cams like 288's.
    therefore using a 3.94 r&p with high duration cams would mean you would be shifting at the beginning or midway through powerband and obtainable potential of 288's would not do as much as a 264 cam with your r&p.
    just food for thought.
    ~\\VoLkS//~\\MaN//~
  2. #82
    Sep 2007
    high duration cams dont necessarily correlate with high top end power. nor does having a higher final driver equate to having better acceleration.
    with your tdi 5th you'll be able to cruise at sane RPMs but the difference between 4th and 5th will be maaasssivve.
    if you plan on going FI or big power, you should keep old ring and pinion because you'll want the taller gears to wind out. (as tim said!)
    to make total use of the 288s.... you'll need a lot more than better gear ratios..
    87' MK2 GTI
    13' MK7 TDI
  3. #83
    Feb 2008
    mOOROOLBARK
    Quote Originally Posted by VOLKSMAN View Post
    sorry mate i might of been a bit confusing there, i got a bit of ahead of myself when i said that
    i was thinking 262 autotech cams but iv realized there a bit low for what i would need
    like you said i would probably need something like that 264, or DRC 268s which are pretty much schrick 268 copies but only half the cost
  4. #84
    Feb 2008
    mOOROOLBARK
    Quote Originally Posted by jayjay View Post
    iv decided against fi for now its not worth putting the extra stress on a tired 200 thousand k motor
    how does my shorter final drive not equate to better acceleration?
  5. #85
    Sep 2007
    i just think it effectively means more shifting in the process of accelerating... i find that i'm no human-dsg and 020s and 02as don't have the quickest rifle bolt action shift either.
    Doesn't a final drive effectively equate to a closer ratio gearbox? ( i'm not trying to question your choice or anything, i'm just getting my head around )
    87' MK2 GTI
    13' MK7 TDI
  6. #86
    Dec 2008
    Liverpool NSW
    to make total use of the 288s.a... you'll need a lot more than better gear ratios..
    now having a higher duration like a 288 cam makes peak power at much higher rpm than say a 264.pretty much you will have minimal torque before the engine rpm is high enough to maximise lift.this is why 288 are for race and 264 are for street applications. i hear this in numerous NA builds and it sounds pretty much common sense.
    as for gearing 3,94 does create better acceleration compared to stock gearing besides head work done however you are sacificing top speed in that gear for acceleration another reason "i think were are pretty much saying the same thing"
    as for 288 application major head would need to be done to increase cfm (air flow) to see get the best out of these cams.
    ~\\VoLkS//~\\MaN//~
  7. #87
    Feb 2008
    mOOROOLBARK
    (quoted by preen59)
    Ring and pinion affects the final drive, so all gears are affected. The ratio between them remains the same.
    In this case, "shortened". So the maximum speed in every gear is reduced, but acceleration is improved by the increased ratio. Think of it as using a lower gear on the crank (front sprocket) of your pushbike..
  8. #88
    Dec 2008
    Liverpool NSW
    pete have you tested each gear for top speed (legally), interested in knowing how much speed is lost?
    also i highly advise you to reconditon your cylinder head before you install cams saves time and money.
    i know headworld can do a service and match port for around $1000.
    ~\\VoLkS//~\\MaN//~
  9. #89
    Feb 2008
    mOOROOLBARK
    nah mate i havent got the box built yet
    il be getting this work done all at the same time
    lets see here
    recoed box- 3.94 r&p, taller fifth gear, peloquin diff
    timing chains
    sachs clutch
    mk4 head gasket
    cams once iv decided what to get
    chip to suit cams
    maybe the schimmel intake not sure on that one yet
    fuel pump
    r32 sump with pick up (my sump has had it may as well upgrade)
    thats it i think
    thats a good idea but all depends on condition of the head plus the budget
    also id prefer to keep the work to the one shop, volkwerke are pretty good so il see how i go
  10. #90
    Dec 2008
    Liverpool NSW
    great list.
    but i dont know why are you choosing an r32 sump when the 12v is steel rather aluminium (weak), plus you will have to increase your oil fill-ups by half a litre which i find irritating when you cant find 5.5L + Bottles. and you will have modify the sump to fit from what i remember there is an extra bolt up on the Bell-housing side
    ~\\VoLkS//~\\MaN//~
