Page 16 of 17 FirstFirst ... 614151617 LastLast
Results 151 to 160 of 165
Thread: Thread that combines all my car threads
  1. #151
    Jun 2007
    Eastern Suburbs Melbourne
    don't forget to fix those plug leads
    i like volkswagens
  2. #152
    Sep 2010
    Southern Highlands NSW
    Congrats Pete, much deserved bud ! Hope 2 see the VR with the bigger exhaust at sedf
  3. #153
    Feb 2009
    Quote Originally Posted by mk3pete View Post
    i got bored at work so i decided i would delete my MAF housing
    Hi Pete, just passing by and wondered how you'd you go with this MOD? I really want to do it myself, is there perhaps any pointers or measurements you can swing my way? Thanks.
  4. #154
    Feb 2008
    mOOROOLBARK
    its 3'' stainless tube and the smaller tube didn't quite fit tight enough so i used a larger o ring on the sensor
    for measurements iv forgotten what everything was exactly
    you just have to take the sensor out and see what size tubing would fit, and then make sure its the right length so its in the middle of the 3'' tube
  5. #155
    Feb 2008
    mOOROOLBARK
    bit of an update today
    thought id share what iv done in the last few months and where it will be going in the future
    rear wiper delete
    also deleted bottom plastic bits...wat ever you call them
    i do have a tow cover on just not in that pic
    the day i got my wheels
    what a bitch of a job to install the phenolic spacer.... everything went wrong
    all 3 bolt holes stripped thats holds the belt tensioner on (first pic)
    lucky i had some spare exhaust studs M8 that were longer than the oem bolts
    found one of my leads was broked had to jb weld it back on
    all this the day before DOVW.......
    i done a lot of wire neatening at the same time.
    i used self amalgamating tape, great stuff really easy to use and comes up a treat.
    i used two rolls of the stuff, got it from autobarn 16 bucks each but worth it.
  6. #156
    Feb 2008
    mOOROOLBARK
    also done the IAT relocate
    no pics but today i installed neuspeeds lightweight pully kit
    crank (massive difference in weight also slightly underdriven)
    power steering (slightly larger than oem makes up the difference in the crank)
    alternator
    and gruven parts
    tensioner pully and waterpump pully
    very big difference in acceleration
    future plans are to get it dyno tuned with this
    www.lugtronic.com
    also bigger exhaust and these
    VWVortex.com - FS: S2 Metalwerks Headers for VR6 $675
    (i couldnt find there website but this is an example)
  7. #157
    Point Cook, Vic
    have you managed to get in touch with lugtronic to see if their ECUs work properly on our cars? If so I reckon it would be a pretty nifty setup
    FOLLOW US ON FACEBOOK
  8. #158
    Feb 2008
    mOOROOLBARK
    not yet man i dont think this will be for a while at least not until i can afford it.
    but it does state it works for early obd1 vr6
    can you bring that keyring tomoz man il be comin along;
  9. #159
    Point Cook, Vic
    bugger! Ill have to go past the warehouse and pick one up in the morning. Its not far from the meet point so it shouldnt be a hassle.
  10. #160
    Aug 2006
    Melbourne VIC
    So good!
    Im glad you are happy with the wheels/tyres...
