give us a shout over the weekend Ill come over and see it. Might need your help soon to get this engine out!!
Wide Steelies For Sale
http://www.vwwatercooled.org.au/foru...ies-76972.html
96 Audi Cabriolet : a.k.a THE MANBROLET
06 Golf GTI : GIAC stage 2, FORGE twintercooler, 3" SPM downpipe and exhaust, hpfp
99 Audi A6 :The White whale
no worries i have tools!!
im moving out this wk end though, goin to the misses parents house to save more money![]()
i got bored at work so i decided i would delete my MAF housing
You can do that?
I'm so doing that...Pete, can you make me one?![]()
Good stuff Pete, I am looking at doing that for my mk3.
now that my maf is further away from the throttle body it seems to run a bit richer and has a lower idle
anyone care to explain why???
Pete it looks like the maf sits further out of the centre of the pipe than it should (reading air flow, hence best to put it directly in line?)...that could explain things maybe?
a mass airflow meter works by heating up a thin metallic wire to quite a high temperature. The difference in voltage potential across the wire is measured as a rate of change as the air flowing through the inlet is used to determine what mass of air is passing through the cross sectional area.
basically. wire gets hot. air going in cools it down. as the hot wire gets colder, the voltage of the sensor changes --> change in mass of air.
The grid and shape are really all quite important for the maf to work within factory parameters
87' MK2 GTI
13' MK7 TDI
