got my tints done today whooo
pics after DOVW
mk5 sumps give an extra half inch clearance plus they have baffles
sits above subframe
not sure about the extra bolt, i know i have to drill a hole in the baffle to allow the dip stick in
pics after DOVW
well my cars finally in the shop
ported and polished big valve head
eurospec 268s
hd springs with l/w lifters
+2 intake
+1.8 exhaust
new valve guides and seals
the gear box is in bits for now
it will be a full rebuild
new bearings and 2nd gear synchro
3.94
peloquin LSD
tdi 5th gear
sachs stage 2 clutch
lightened flywheel 13 pound
You have to take me for a run in this when she is all done Pete!
You got the balls to do what I was planning for years
hey yeah your head has the same marks/depressions between the coolant galleries as mine does. i called Rob about it, he said he didnt worry about welding it up and resurfacing it cos its between the pressure lines on the head gasket.
yay for engine work!
-steve
fly wheels almost before i started machining it
after
balanced
odb2 intake mani gasket matched
had to get it modified to suit obd1
larger throttle body to suit mani
also have to wire it to suit old managment
old one
other random goodies that will be replaced
water pump
thermostat and housing
oil pan
filter housing
coolant expansion
crack pipe
Nice dude, nice. Keep it up!
Was good to catch up with you again at SEDF Pete. Can't wait to see this done and rolling!
wohoo!!! cant wait to see this thing done matey![]()
cheers guys
tim...... 3 words for you JUST DO IT!!!!!![]()
