Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 63
Thread: Thestu's Vento VR6T Build Thread!
  1. #51
    As much as I'm all for a turbo gas setup & had located & puts some parts aside to do it to my mk1 at one stage, the fueling side is easy to do.
    You need to start with a standard GAS install setup, but you'll need a boost reference (modified) B2 gas convertor. You may need 2 of them depending on your planned power output, as one may not be enough.
    You'll also need a Gas Research carby/throttle body.
    Tuning/getting the right mixtures is the next problem.
    Its about getting the right size Throttle body, the right size venturis, metering rods, progressive hose jets etc. spot on.
    It may look like a simple system, but you have to know what your up against & what your doing.
    Cause a GAS backfire is alot bigger than petrol back fire & can blow your intake clean apart!
    Remember. 1L of compressed liquid gas in a bottle is 250L of gas in the atmosphere! YES it is!
    I've seen a setup like this power a Falcon into the 9's, so it can make power when tuned right.
    But.....
    The only thing I think you may have overlooked is you'll still need an ECU (preferably standalone) to control the ignition timing.
    Even the mentioned Falcon ran an Autronic ECU & a Crane Fireball Capacitive ignition system to light fire.
    I may still have the book here on it too.
  2. #52
    Eastern suburbs of Melb
    I love digging through old threads lol
    Ended up getting a mk4 bora and turboing it
    Sent from my GT-I9505 using Tapatalk 2
  3. #53
    Feb 2010
    mk3 > mk4
  4. #54
    Aug 2007
    mk3t > mk4 anything
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
    2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
  5. #55
    I still love Mk3's, but the Mk4 is just that much better to drive.
  6. #56
    Aug 2012
    Kangaroo Valley, NSW
    also all wheel drive.
  7. #57
    also the vr6 had 30 extra kw out of the box and 12 more valves...
  8. #58
    Mar 2012
    Central Coast, NSW
    Quote Originally Posted by thestu View Post
    When you can drive SOON!
    Mk3 has a weight advantage though!
  9. #59
    still remember when you drove my bora back from foffas... "is this standard?" "its so plush!" lol
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  10. #60
    Hahaha yes. It was lovely lol
