VR6 front mount bracket
Hi all,
I've just changed my VR6s front engine mount and found the bracket that joins the engine to the front mount to be loose. Does anyone know if there is supposed to be a bolt going through the bottom hole from the driver's side on the bracket?
- You may not post replies
- You may not edit your posts
Forum Rules
