Results 11 to 20 of 22
Thread: Sydney - MK3 VR6 FI
    Sep 2006
    Australia?
    You won't be able to hit that kind of boost, with a stock ECU it will only handle 6-7psi before you fry the ECU.
    Apr 2009
    Kensington, Sydney
    Quote Originally Posted by DubSteve View Post
    ARGH! Okay fine! DubSteve,
    ECU Included in the list of considerations as mentioned in the early post =P
    Jan 2008
    Newcastle, NSW
    Forgive me Steve, how does high boost fry an ECU?
    Sep 2006
    Australia?
    Quote Originally Posted by schoona View Post
    Can't handle the power not sure, I am just quoting US guys though but I have read this many a time!
    Jan 2008
    Newcastle, NSW
    resistors diodes and silicon burst into flames? lol. I see what you are saying.
    what about ripping an (Eaton?) charger of a merc c200k or something annd running low boost on that??
    Jan 2007
    You can't actually fry an ECU, unless your putting more voltage through it which is physically impossible if you change the data on the map, common sense really. I think its got more to do with the tuners not being happy enough with the stock ECU, whether thats got to do with the existing map or the functionality of it I reckon they're going stand-alone simply because it can make more power reliably at those higher boost levels.
    And alot of OEM vw stuff such as throttle bodies, coils and idle actuators aren't actually adjustable, badgolfiebad for instance is running on Supra coilpacks, R34 GTR throttle bodies and aftermarket idle actuators among other things.
    Jul 2007
    Rowville Melbourne
    i think its the same sort of issue with other cars ECU's when you put too much air into and engine with stock ECU, its sensors are picking up readings that are outside its parameters. so it doesnt know what to do. thats all a chip does i think, just gives it wider parameters to work with.
    thats my understanding of it anyway.
    like on my mates MR2, he just put a smaller pulley on it to make higher boost with his supercharger, he said it will make it 12 pounds instead of 7 or something but if you go any higher than 16 it wont know what its doing and run real crap.
    -steve
    Apr 2009
    Kensington, Sydney
    agree..
    my mate's turbo charged (7Psi) Honda civic running on standard ECU...if you floor it..the engine light comes on and..the car starts to behave weird..
    strange...but from the setup i am looking at..they come with aftermarket chips (C2Motorsport/Giac).
    Do you guys know if these chips have tunablity? or just plug and play (pray).
    Tuning a car after doing something major is must (from my point of view).
    Any aftermarket full tunable or piggyback (like apexi neo) for VW Golf?
    Feb 2008
    nsw
    Quote Originally Posted by chockz View Post
    agree..
    haltech interceptor.
    a4 1.8tq,s4 mirrors,genuine,a8,wheels,black side markers,rs4 grill, apr r1 dv,neuspeed springs 2" drop waiting for haltech ecu
    Aug 2007
    Why pay about $1000 plus tuning for a haltech interceptor, when you could get a full standalone for 1500ish depending on brand plus tuning.
    The problem running any boost on the stock VR6 ecu, is that the air mass meter can only out put a certain voltage (5V i think). On a standard engine it is already putting out 4-4.5V at about 6000rpm. So if you increase the amount of air it will still only output 5V. Also the injector drives in the ecu won't be able to handle running the injectors at a higher duty cycle foe extended periods of time.
    1979 Mk1 Golf 2door (Under construction)
    1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
    2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
