Quote Originally Posted by peedman View Post
What i usually do is lift up a bit using the front crossmember, then put x2 stands on the ends. Then i jack up at the main subframe until im high enough to fit the stands on the rails.
I know some of u haters might say that ill crush the front crossmember mounts but ive done it multiple times with no effect. Just go slow and itll be fine...
Ditto. I use the chassis rails...mine are slightly bent from misuse from previous people anyway so even if I'm doing damage it won't matter much..
