I wish.
Hahaha.
Can't wait to see this thing go, good luck with it.
Well the time has come to supercharge the vr6, the kit is on its way from england, its a stage 2.5 vortech vf9 11psi setup with red top injectors, forge re-circulating dump valve, 4 bar fuel pressure regulator, k&n filter, all silicone hoses with sump pan oil lines and return and much more. The obd1 setup was mapped by a guy called vince at stealth racing in the uk who i believe is a top bloke in his field and is producing 285hp, cant wait to get it, should be here tuesday. Anyone else have a supercharged vr6 on here?
I wish.
Hahaha.
Very cool, keep us all up to date, and if you have the time/are doing it yourself do up an install thread. It won't be the only SC VR6 on here, but there aren't many... mine certainly wasn't.
This I like to hear
Good luck.
That sounds insane!! Love it!!
please keep us updated with plenty of pics!
96 VW VR6 Golf (Daily driver)
65 VW Beetle (Under restoration)
Good to see there is another nutter spending money on VR6 performance mods.
Good luck with the V9 dude
1979 Mk1 Golf 2door (Under construction)
1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
Just FYI the VR6 comes standard with a 4 bar FPR.
Good luck with the build, make sure you have spare belts!
Euro Revolution - eurorevolution@live.com.au
Importing Quality Performance and Spare parts for Audi & Watercooled VW's
New website almost up and running ... http://eurorevolution.webs.com/index.htm
Courtney
Ooooohhh this will be nice! as "vw imposter' said if your doing it yourself make a build thread! will be keeping posted! goodluck mate.
if you dont mind im sure a few people would be interested to know what was spent and after its installed a dyno sheet
Goodluck mate.
I always wanted to do this to mine and still might, just depends if I keep it or upgrade it later this year
Good luck and make sure you share lots of pics with us!
MAEK BUILD THREAT NAO!
Or at least put up a dyno sheet when your done
