just do it man .. i heard that VR6T's are brutal !!
VW BORA 2003 V6 4Motion
Volkswagen Golf MK3 1997 CL 1.8L
Rammstien + Autobahn + Volkswagen = Leben !
Mark (malteser on the forums) has done it to his.
It really depends on your goals with the car, also you budget.
1979 Mk1 Golf 2door (Under construction)
1994 Mk3 Golf VR6T, Autronic SM4, GT30r, Peloquin, 288mm Brakes, B&G coilovers
2000 Audi S4 Imola Wagon, Stage 3, J-fonz tune, F21's, ER SMIC, 034 DP's, JHM DTS, JHM Trio Short Shift, 350mm Brembo 6-pot, ABT coilovers, BBS CH, RNS-E, FBSW, Alpha 2.5 cat back
A supercharger has been on the cards for my car since the day I got... although of late I'm wondering if it's worth it or if I should just sell up and buy something newer instead.
The VF Engineering SC itself is ~US$4,000 (+shipping) but then you need a chip to run it which means either sending your ECU to the States or going aftermarket. In *very* round numbers I would be budgetting $6k - $10k (and probably at the higher end) before you can drive it.
I've been quoted _at least_ $10k for a running supercharger setup in mien dub by golfwagen. TBH, unless you are a mad keen dubnutter, I dont really see the point.
I've had all the internal work done ready for a supercharger - and yeah, very expensive exercise.
I think if you had a "bolt on" kit with no internal work budget between $5 - $8 depending on brands. With internal work, budget double to be safe
I have been told I'm mental.
I'm going to the pub... I may be some time...
