Stock size is 2.25" actually
the better fuel you use the BETTER it will be for your cat mate, it won't have to work as hard crapping out good smoke!
Magnaflow make a proper cat for the mk3 so I think having the oxygen sensor put in should be very simple. You could shoot an email to the seller before you buy if you're a bit worried about it, I'm sure they'll answer your question. I'm not sure about the heat shield but I'd take a guess and say the magnaflow will fit above it cos it looks small!
EDIT: My bad, stock size for the VR6 is 2.25"...someone with a GL will have to tell you your stock size lol.
