Page 4 of 107 FirstFirst ... 234561454104 ... LastLast
Results 31 to 40 of 1069
Thread: The Stu's Bagged VR6 Cab
  1. #31
    Eastern suburbs of Melb
    Quote Originally Posted by mk3pete View Post
    stu i am so jealous of your steering wheel
    are you being serious its hideous!!!!!!
    any way to fit different air bag wheels people??
  2. #32
    Jan 2007
    Quote Originally Posted by thestu View Post
    Be glad its actually intact and not cracked, which disintegrates in your hands whilst your driving Mine too is also intact
    As for aftermarket wheels, your best bet is to find a 3.5 cabriolet and fit the steering wheel and all onto the VR6 column.
  3. #33
    Feb 2008
    mOOROOLBARK
    by all means if ya want to sell it to me be my guest
  4. #34
    ok lol so i get the home and go for my first cruise... after about 20 mins starts smelling like a rotten egg... weird but i thought it may have just been because the heater core needed replacing...
    guess not. got to maccas at a later stage...30mins later turned it off went back and she wouldn't start...DAMN IT! so i popped the bonnet... to find a very hot battery that was steaming! so i called my free racv cover and a guy came and had a look....the battery pulled 2 volts when it tried to crank and 13.5 when it was just sitting...then we started the car of a jumper pack and the alternator was cranking out 17.5 volts.
    alternator is screwwwwwed! where do i get one and how much???
  5. #35
    Camden, Sydney
    Wow thats overcharging mate. Pm me for an alternator if you need. I`ll give you a free green strip with it
  6. #36
    Oakleigh VIC
    Stu, I've still got a heap of Mk3 stuff here. Including a few alternators and a servicable MK3 battery.
    (Although a GL and VR alternator might be different)
    Pete
  7. #37
    some work:
    took me 20 mins (and i had no idea how to do it ) i just ripped the front off the car and took the alternator out.
    then i decided to give the car a wash and some places a buff where some scratches were...most came out but i couldn't move the car to where a had more space so i only did a little bit.
    not a bad little unit!!!
    also had a question about the gauges...this is when the alternator was stuffed...have not tried it with a new alternator (hopefully it fixes the problem). As soon as the throttle left idle the gauges (fuel, temp, tacho, speedo...but the trip stayed and the time.) would just drop out. the air bag light and the abs light also came on. about 5 seconds after it returned to idle the oil pressure and handbrake light would flash and the gauges would read again.
    would this be an earthing problem or would the high voltage from the alternator and the 2 volts from the battery would have been confusing the car?
    also if all the things like a/c, headlights and so on were turned on the guages would drop out when the car revved to about 2 grand...
    any ideas? hopefully just the battery and alternator problem.
  8. #38
    Oakleigh VIC
    The voltage reg that controls the power to the gagues should auto protect by shutting down on over heat, or over voltage so yes it could be alternator related.
    Pete
  9. #39
    Pete
    score
    i tried calling you again pete..you didn't answer i may have to drop around 2moz i got side tracked today
  10. #40
    Aug 2006
    Melbourne VIC
    The dude who works at Volkspower with the VR6 said she needs a bit of work but all should be good. Dean, him and the south african bloke were at the Island today!
