Does the needle shake...
Sounds like the cluster has packed it in, not an altogether uncommon failure on the VR6.
A brand newy is damn expensive, but on the upside, you will be starting with 0KM
A second hand should be fine (mine is) and may come with lower km's to boot.
Depending on which model you have you can swap out individual parts if you want to try and repair it, but it's usually easier to get a new one.
