Results 1 to 10 of 10
Thread: speedo gone bung
    Feb 2007
    Perth, WA
    speedo gone bung
    Hey fellas
    I have a bit of a problem, my speedo has died. Everything else in the dash works just fine, except speed and revs. Does anybody know what could be causing it and how I might be able to fix it?? Not really keen on waiting until after easter to get it up to golfwagen :\
    Sep 2009
    I think the clusters are a pretty common item that fails unfortunately :/ Will probably need to swap in another one.
    Feb 2007
    Perth, WA
    I was hoping that wasn't the case, since its only speed and revs - not everything :\
    Feb 2010
    Can you just swap the speedo and rev gauges and retain the rest of your cluster? Thats what I did in my E30 so I could keep the right Kays
    Apr 2010
    Albury
    Try disconnecting battery It might work again for a little while longer.
    And Im sure you have to buy a hole cluster its all one part.
    New one From VW is around $700+
    It's Hard to find a second hand cluster with decent Ks on it,Most 200,000ks +
    Sep 2009
    I believe there is a way you can set the kms with some software so that its right.
    Theres a write up on the vortex about a way you can fix some of the clusters by resoldering some things. If youre handy with a soldering iron it would be worth searching for that and giving it a try.
    Sent from my HTC Wildfire using Tapatalk
    Feb 2007
    Perth, WA
    I am pretty good with a soldering iron actually, might give it a whirl, thanks!
    Is there any possibility it could be fuse related at all?
    Jan 2010
    If you can find the VSS (Vehicle Speed Sensor) a 3 wire clip on the top back of the gearbox near the reverse light switch and chekc that! I had the same problem a while back and it was that was loose.
    Sometime a faulty ignition switch can case it too
    To get the cluster out is pretty easy to check, check the forums for proceedure
    Quote Originally Posted by MattyT View Post
    North Beach WA
    Give me a shout if you're still having probs with your speedo. I got a couple of recon units here in stock OR can get yours repaired. Thanks, steve@waeuro.com.au 0449000660
    He who dies with the most toys wins!!!!!!!!
    2000 Golf 3.5 Cabrio lowered, low ratio box black-on-black-on-black
    2010 Tiguan TDi Manual Stage2 tune, DPF delete Egr delete
    2008 Jetta BWA DSG Stage 2 tune, 3"VF intake
    Formally known as WA 79 cabby
    Feb 2007
    Perth, WA
    Cheers fella, ended up getting it sorted at Golfwagen a little while ago tho.
