Results 11 to 20 of 37
Thread: Speedo Calibration
    syncro Guest
    Quote Originally Posted by peedman
    It cant be out by more than 10kmph which is the legal boundaries by which ur speedo can be incorrect by. That might have changed tho.
    No it's 10%.
    Oct 2006
    Hehehe my bad. I really wouldnt worry about it, you would think that if u were doing 61kmph in a 60 zone the coppers wouldnt pull you over.
    Jul 2006
    Sunshine Coast....Moved up in jan 06 from Tas
    im getting new tires put on my car and there 2cm smaller profile and the mechanic said my speedo would be out... sounds to me it wont be more than 10% so sould i get it checked out or dont worry about it
    Sep 2006
    West Sydney
    Try playing around with this program:
    http://members.optusnet.com.au/~sthchan/tiresizer.zip
    It's similar to the link that golf3 posted.
    Another tyre sizer program thingy can be found at http://www.1010tires.com/TireSizeCal...?action=submit
    All three are very useful, and should give you an idea of what size tyres you should really be using to keep the same overall diameter (or something close enough to it).
    syncro Guest
    Legally, replacement tyres should be no larger than 15mm more than any optional fitment.
    A Dunlop 205/55x16 may not be the same diameter as a Toyo 205/55x16.
    Apr 2006
    Question
    All good info!... however, this still doesn't account for my 80-100km loss per full tank of fuel.
    According to a -3.2% differential with the new tyres - i should only be losing around about 25-35kms per tank..
    hmm, well i've just refuelled again, we'll see how far this gets me
    VW Golf MK3 1.8L
    Mini Tanks
    syncro Guest
    The tyres may have more rolling resistance.
    Oct 2006
    Yeah I sorta agree. What tyre pressure you running? But 80-100kms is pretty high if its just bad tyres tho
    Sep 2006
    Tweed Heads
    Hoyhoy.
    For a start legal tolerances are now only 3%.
    So if you want to find your true reading, you will have to ring around in Syd. Look in the yellow pages under speedometers. I done this on the Gold Coast & on the third Ph. call found a bloke who would check the speedo with a mobile GPS plotter which is accurate. Got it in writing, cost me $30.00.
    Hooroo.
    syncro Guest
    Quote Originally Posted by Eddy
    Hoyhoy.
    I have never seen a speedo that is within 3%.
    Read this thread;
    http://forums.vwvortex.com/zerothread?id=2938451
Similar Threads
  1. Speedo light in Dash how do u change it?
    By XXX-1.8T in forum Mk1 Golf
    Last Post: 25-10-2006, 11:39 AM
  2. Speedo cables
    By roccodingo in forum Mk1 Golf
    Last Post: 06-10-2006, 12:20 AM
  3. Speedo Cable vs Gearbox
    By hiho in forum Mk1 Golf
    Last Post: 29-09-2006, 07:24 PM
  4. new beetle speedo
    By blutopless2 in forum Mk4 Golf & Bora and New Beetle
    Last Post: 05-07-2005, 08:05 PM
