Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Speedo Calibration
    Apr 2006
    Thumbs up Speedo Calibration
    Hi guys, long time reader... (great forum!)
    Ive just had 17" wheels put on the car (from the stock 14") and i think its put the speedo out of whack, anyone know where i can get the speedometer re-calibrated?
    Dont want to stand there arguing with the boys in blue about how i WASN'T speeding
    Cheers guys
    VW Golf MK3 1.8L
    Mini Tanks
    syncro Guest
    Quote Originally Posted by wayz
    Cheers guys
    Check it first as it may be within limits.
    They normally read about 5-10% fast.
    Apr 2006
    How would i go about checking it? (forgive me ignorance )
    i normally do about 550 nearly 600km a full tank and now im doing only 450 or so a tank? This happened immediately after i had changed the wheels. Would anything else be wrong?
    VW Golf MK3 1.8L
    Mini Tanks
    Feb 2006
    Camberwell, Victoria
    Heavier wheels = more unsprung weight = more power required to make them/the car move = more petrol = more $$$
    Apr 2006
    Exclamation
    Arhh, yes.. i thought about that, but these wheels are actually lighter and the car feels like its driving with greater ease
    VW Golf MK3 1.8L
    Mini Tanks
    Feb 2006
    Rolling diameter will be different every time you change tyres, even when still the stock size of 185/60R14. Tyres are all different. However, with 17's you should be running a 205/40R17 or similar to keep diameter to around the same...
    Apr 2006
    Exclamation
    Quote Originally Posted by golf3
    I am running 205/40R17's
    But im pretty sure they're a larger diameter tyre, and that would make the difference im guessing/hoping, otherwise im baffled and my car is in desperate need of a tune-up
    VW Golf MK3 1.8L
    Mini Tanks
    syncro Guest
    Check your odometer on the M5 speedo check.
    Drive next to someone and have a look at their speedo.
    Drive really fast through a speed camera and wait for the photo.
    Use a GPS.
    Feb 2006
    http://www.miata.net/garage/tirecalc.html
    Using stock of 185/60R14 to 205/40R17
    Speedo reading with non stock tyre is 3.2% too slow...
    You are actually doing 61.9mph when the speedo reads 60
    Oct 2006
    It cant be out by more than 10kmph which is the legal boundaries by which ur speedo can be incorrect by. That might have changed tho.
Similar Threads
  1. Speedo light in Dash how do u change it?
    By XXX-1.8T in forum Mk1 Golf
    Last Post: 25-10-2006, 11:39 AM
  2. Speedo cables
    By roccodingo in forum Mk1 Golf
    Last Post: 06-10-2006, 12:20 AM
  3. Speedo Cable vs Gearbox
    By hiho in forum Mk1 Golf
    Last Post: 29-09-2006, 07:24 PM
  4. new beetle speedo
    By blutopless2 in forum Mk4 Golf & Bora and New Beetle
    Last Post: 05-07-2005, 08:05 PM
