If you would need spacers comes down to rim design, some needs to be spaced out to clear the brakes,some don't.
Would go for the 205/40 just to give that lil bit more clearance to go a bit lower and also avoid/lessen rubbing issues.
Leigh
Hi all, looking at a set of rims for my 94 VR6. They are 17x7.5 with an et of 32. If my calculations are correct, they should go straight on and I dont think spacers would be needed but can anyone advise for sure?
Also, what is a reco tyre size? im thinking either a 205.40 or a 215.40. Id prefer a 215 as I want as much rubber underneath as possibele. You think a 225 would be pushing it?
Advice appreciated. cheers all....
As above, that model wheel should go straight in
awesome.. cheers guys
not mine sorry.
think it had 205/45 on it at one point (too big in diameter) and 205/40s (much more suited to mk3 factory rolling diamters)
not sure which this photo is on
