Hey guys, bit of a problem I can't quite work out. Hit a pot hole coming home a couple of weeks ago, damaged something in the steering.
Drives ok under acceleration but shoots off to the right when backing off.
Also now have a horrible rubbing type noise, does not sound like metal on metal tho, sounds like coil over on wheel?
Wondering if wheel bearing has possibly collapsed or is it more likely to be a ball joint/ rod end problem?
Really need help ASAP guys as I can't drive it ATM.
Cheers mike.
