Results 1 to 6 of 6
Thread: Snap!
    Feb 2006
    Camberwell, Victoria
    Snap!
    Pulled into my driveway last night, and the car started to shake hardcore, and knocked as it was driven...I thought...ARGH! But lucky it happened when i got home!
    One broken front engine mount...I had a spare, so i've already fixed it in time for DOVW, but I don't think its the right one for the 4cyl with 02A gearbox.. So, if anyone has any ideas or any spare ones lying around. I looked at a vr6 one, but its way different to the 8v item, or is that the one i want?
    Currently it has 3 bolts holding it there, one on the mount, and the two the hold on the starter, is there meant to be a fourth? Because there is a hole on the gearbox for it...
    I have a couple floating about if you can get me the number off the broken one I see if it matches mine.
    Camden, Sydney
    I`ve got one the same as that one that is broken. Dunno about a 4 bolt one.
    Apr 2006
    VW Race HQ - Sydney
    I always had doubts about the strength of this part and also the strength of the front engine mount carrier . Cause of the ridiculous torque the VR6 will generate I'll be bolting the engine and box directly to the chassis or subframe without engine mounts . The front frame support will be integrated to the roll cage which in turn will be welded at numerous points along the front beams/chassis .
    i think you may need to check all 3 engine mounts to make sure the engine hasnt been rocking causing it to break
    Camden, Sydney
    Quote Originally Posted by Bug_racer
    Amen to that.
    You broke it pretty good though Sean
    Sep 2006
    Australia?
    SNAP yes indeed. Looks like you clean cut that one WOW!!!
    How did it happen? Did you go over a massive pot hole???
    My mate said he went over a pot hole and his chassis at the front snapped, his on this forum cant remember what his name is though.
Similar Threads
  1. 2.0 Tdi Oil
    By TDI DSG in forum Fuels and Lubricants
    Last Post: 02-01-2008, 08:37 AM
  2. pics
    By william in forum A Photo Gallery of our Rides
    Last Post: 07-12-2006, 01:37 PM
