Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Smoke coming from steering column
    Oct 2012
    Try turning the thermostat to heat and if mist comes out the vents you can be fairly sure its the core. Just bypass it with a corner joiner from bunnings but dont plug the tubes. And then fix it when you get the chance
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    Jun 2013
    Yes, thanks a heap! To bypass the heater core do I remove the intake and outake tubes and what an L tube there instead?
    420 dank blaze it
    Oct 2012
    Yep thats the way.
    Jan 2010
    sounds like heater core....
    There is a vent in the firewall (engine bay), centre low down, to drain it.
    If you take your passenger side blower out you can get a mirror in there to see in
    If not try your cabin filter under the water deflectors
    Q
    You can use the existing pipes to bypass.
    Jun 2013
    thanks guys, did the bypass and it has been fine since. fuaaakin cant be bothered doing the heater core replacement.. too much effort haha
    420 dank blaze it
