Results 1 to 10 of 11
Thread: Slow cranking
    Sep 2006
    West Sydney
    Slow cranking
    Battery was weak and couldn't hold a charge so bought a new one. Installed it just then only to find that the car still cranks very slow (like it was still on the old battery), but it does start. Sometimes it just clicks, with no cranking whatsoever. I've cleaned the terminals with a wire brush, as well as the cable ends.
    Could this be the starter?
    Jan 2007
    Mines doing that as well, accompanied by a sickening spinning noise, starts first go 3/4 times though, my money would be on the starter.
    Quote Originally Posted by rayray086 View Post
    Just from left-field... Ignition Coil / Coilpack?
    http://www.cardomain.com/id/sydvr6
    Subaru WRX Wagon 06 + Peugeot 306 GTi6
    Apr 2009
    Newcastle NSW
    starter solenoid maybe ?. I had the same problem on my old feroza, replace the solenoid and was like new.
    Sep 2006
    West Sydney
    I'm thinking it's the starter too as it still does it with the new battery and wire-brushed terminals and cable ends.
    It doesn't start then die, or die while idling, and when the crank does turn, it will start up, just very slowly, so I'm I don't think it's the ignition coil. On occasion it just clicks though (when turning the key).
    Feb 2008
    mOOROOLBARK
    Quote Originally Posted by stotto View Post
    im thinkin it may be the solonoid also
    common problem with the starter motors are when they stick on and make a horrible noise
    had to get mine refurbished
    havent really heard of them being slow though
    Camden, Sydney
    Its an earth fault on your car Ray.
    Get a better fatter earth cable, or two. Make sure all the ends are tight and earthed to a good metal point of the chassis and engine.
    Also check the live points on the positive part of the circuit.
    Sep 2006
    West Sydney
    Just that it used to start up just fine before, and I was using the same cables...
    I'll try using thicker cables. A lot cheaper than another starter anyway!
    Nov 2009
    Check all the cable connections are clean and tight. I had a bad earth connection in a diesel golf once...after a few cranks that main earth cable would actually get warm.
    Also a worn starter can cause slow cranking - as if the battery is flat... a friend had that problem with a Rodeo.
    Sep 2006
    West Sydney
    Turned out it was the alternator - wasn't charging the battery!
