Ok, after a service and a check over at TCCA they found a hole on the underside of the hose running from the Air Map Sensor (or whatever the black box is that sits on top of the engine). Had it replaced and all seems to be running ok.
The car is still running a bit lumpy and over the weekend i experienced starting issues. The car cranked over but wouldn't fire up. Eventually got it going but unsure of the cause.
I've replaced the Ignition Coil and swapped out the Fuel pump relay (167) incase there was issues there. Still waiting for my ECU Relay (30) to arrive and then i'll change that.
However when i had a service, they ran the VAG COM unit and it showed a camshaft sensor fault. Could this be the problem with the car not starting?
Quoted $250 to replace and fit new part so want to ask before i drop more coin.
Jon
