The indicator is teh same but the bold holders are different.
So you need the Mk4 bulb holders to run Mk4 indicators in a Mk3.
does anyone know if the side indicators for the later mk3 (96+) are the same as on a mk4, ie identical swap?
thanks man, i guess its a fairly cheap and simple mod if you have them lying around
which part do you need...? not exactly sure what you ment James
you could always join it into the loom, thats what i did....but you'd need connectors and heat shrink gun...and to know what you were doing too i suppose haha
