Page 42 of 47 FirstFirst ... 324041424344 ... LastLast
Results 411 to 420 of 468
Thread: should i bore u with another build thread?
  1. #411
    Quote Originally Posted by KI11Z View Post
    I need more people like you in my life to slap me from time to time . . . Cheers!
    nahhh wurries anytime
  2. #412
    Sep 2006
    Parkinson / Brisbane
    Quote Originally Posted by byza View Post
    Dude the hectiva looks soo good... you still chewing tires every month or so LOL....
    well done... my screws are on the way from Japan and then wheels go into the booth for paint... hopefully comes out alright... next i will need MOAR LOWWZZZ...
    Hey Byron, mate we'll have to catch up, your one of those dudes that I keep meaning to get in cantact with but never do lol, anyway cheers for the props though it looks better in person I reckon and looking forward to the new works! I'll come down and peep'em once you get'em painted up
    oh, and nah, I fixed up the massive 14mm toe in a while ago due to being rediculously unsafe on the highway in the wet! The arse was all over the road to the point where people were hanging back and not overtaking, scary fun . . . I enjoyed squeeling on carparks polished concrete floors though, really miss that
    So no, the same really bad uneven camber wear but wearing at a normal rate now
  3. #413
    Sep 2006
    ok, have I lost the plot!? has this daily gotton outa control?! I want to run a slim plate at the front so . . . It's basically the same price to have an original made in slimline or get a custom combo . . .
    Do I or don't I?! (colour undecided)
    also someone already has HEC71 so I gotta spell it with a K . . .
    Can someone slap me?
    lol, or inkeep with the silly theme! I'm always hungry so it's appropriate . . . lolz
  4. #414
    Jun 2007
    Eastern Suburbs Melbourne
    Stop wasting money on a bleeding glorified kia!
    Hurry up and finish the vr6!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    i like volkswagens
  5. #415
    Dec 2007
    Ermington, Sydney
    HAHAHAHA I'd so do it but meh dude it's up to you. I'd just go with normal plates lol..
  6. #416
    Sep 2006
    hey! that hurt! lol, mazda powerhouse, kia shell and Ford badging. How can you go wrong with three large companies designing one car!
    Quote Originally Posted by Mrk_Mickey View Post
    i'm going to sleep on it, if I do it'll probably be homer ftw
    Just found out though it's only 82bucks to have a slimline standard issued?! will look into it also . . .
  7. #417
    Sep 2006
    aight, 80bucks will have your current standard plates remade in either slim or standard sizes, so i've gone with slim front and standard rear. Sorry, but no homer for the moment, I came to the conclusion that the price of those plates could almost fund getting the diff and final drive installed into the vr's box!
    So i'm just going to standardize the interior, re-adjust the front camber, amber corners and leave it be
    Now to finish the other euro thang!
    I received my replacement headlights from NZ yesterday (Big thanks to Joe (joevr) and John (vert1)) and immediately began installing my painted and projected inserts into them; Only to realize that the rear of the projector fouls on the housing
    So now i'm going to have to push the projector further in forwards towards the glass to give me enough clearance to still utilise the cap and retain a sealed headlight.
    Over the weekend i'll need to find another fitting to step up a size for the shroud so that I can cover up the bulb reflector because once I push it through it'll be exposed. And before you say anything, no I won't be able to use the end cap the way it is atm, i'll be modifying it by cutting a hole in the center and plastic welding a "cup" on the end.
    Can the glass flutes be sanded down so that they don't disrupt the projector light output?
    pics for googling...
    when the replacement lights arrived I threw them on to see if they were all good and yes they'd been joey modded by the previous owner.
    The difference
    and the ****ty part
    Hopefully some positive updates over the weekend...
    Also engine parts are being boxed and tagged for delivery to 101 Motorsport, so the mechanicals are getting love too at last!
  8. #418
    Sep 2006
    West Sydney
    Hey Alex, in regards to sanding down the fluted part of the lens, yes it can be done, just a lot of work as with all things to do with sanding.
    This one guy sanded down just enough for the projector beam -
    Before:
    After:
    His DIY:
    1. Buy a pair of plastic lenses
    2. Mark the outside of the lens with a circle using a Sharpie where the projector is.
    3. Use 60 or 80 grit sandpaper in a circular pattern on the inside where you marked, careful not to wander into the other fluted areas
    4. Progress to 220 grit until all deep scratches are gone
    5. Progress to 400 grit with water grit until you see a uniform haze without scratches
    6. Progress to 1000 grit with water until it looks clear with water
    7. Progress to 1500 or 2000 grit and get as smooth as possible. When dry, they should look about like Scotch tape.
    8. Use Megiar's PlastX to polish until perfectly clear.
    For what it's worth, there has been others that retrofitted projectors without sanding down the fluted bits of the lens. Projector beam isn't as sharp but light output is still tons better than stock. I don't know about the beam refracting onto the other side of the road, but if pointed correctly it should be minimal.
    A solution would be to source a set of FK Vento/Jetta headlights and used their lenses instead, as they are clear to begin with, no flutes.
    Also with the projector protruding behind the housing, I think your projector is sitting quite far in at the moment. Most try and locate them as close to the lens as possible to try and avoid as much projector beam distortion as possible (especially with a fluted lens). Though this does mean modifying the backing of the reflector of the headlights so the projector can be bolted on...
    Either way, you could possibly try and extend the end cap of the housing? -
  9. #419
    Sep 2006
    Quote Originally Posted by rayray086 View Post
    rays big post
    Ray, your reply is below!
    Quote Originally Posted by JoeVR View Post
    No hassel what so ever, sorry I couldn't get 'em when I was there to save postage.
    Loving the progress man, I've gotta come round and check it out when I get my s**** together (and wrangle a car that actually freakin works.....old euros hey).
    For something you talk about like a track-hack, it's coming together like a freakin show car (and not the wanky playstation 3 and 22" chrome kind either... the good kind).
    Keep up the insanity, you've impressed me with your madness from page one.
    It's all good, it worked out aight though two mounting tabs were broken during transit were supposedly all good when they left NZ so bad luck for me, i'll deal with it.
    the track hack project has morphed into the "something on the side i'm having fun with" project and is taking ages! lol, I just don't have enough time or monies to make it happen overnight however i'm in no rush, it's just everyone around me pushing for it to be completed including my mum who wants the garage back! haha
    There's a little bit of projector progress though no pics because i'm still sifting through ideas; So I thought i'd share my new hectiva's number plate and it's mounting and the quick pinstripe I added to tie the rims to the car
    Whoever spots something odd and uneven about the Hecti goes in the draw to win a pair of old butt sludged undies I found in the valley last weekend . . .
    Oh! and that stupid little blue F15 sticker on the ds fender has been cleared over! I can't get the damb thing off :pissedoff:
  10. #420
    Aug 2006
    Melbourne VIC
    Nice work on the hectiva
    Looks like she has some rad camber going on the back there...
    But please put your number plate in the normal spot, its not like there is a FMIC or oil cooler
    BTW I do like the front lip and sill covers....
