Page 1 of 6 123 ... LastLast
Results 1 to 10 of 57
Thread: Servicing VR6
    Dec 2006
    Kilsyth, VIC
    Servicing VR6
    Right, most of the little things have been sorted now, but in getting the air con, heating and a few sensors fixed I completely forgot about the oil and all that general maintenance.
    Not being sure when the last time anything was done I think it's time to replace a few things.
    Air Filter is already done which leaves:
    Oil Filter
    Oil
    Check gearbox fluid level, replace/topup
    Brake Fluid (needs a good bleed at the very least)
    Check Brake Pads & Discs
    Fuel Filter
    Power steering fluid
    Spark Plugs, although I don't have a spark plug puller so that may prove difficult. Possibly the leads too, but we will see.
    Have I missed anything?
    What are the recommended fluid types/brands people use? Am I likely to find the parts at a Repco/Super Cheap/Auto One/Auto Pro... we have a few in Campbelltown. Failing all that there is Golf Loon, or WORST case McGrath Parts
    Oct 2006
    Coolant flush? Prob keep with genuine fluids if ur just topping up. The repco/supercheap oil filters are smaller than the genuine ones so i'd prob go back to original for that, the oil can be debateable. I'll be using synthetic stuff when i drop my oil.
    Point Cook, Vic
    go to imparts and get oil filters from there. They keep getting cheaper every time i get one. I got 2 last time for just over $20
    FOLLOW US ON FACEBOOK
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by peedman View Post
    Coolant flush?
    Already half did that when I replaced one of the temp sensors and lost half the coolant otherwise that would be on the list too (damn the red coolant is expensive )
    Any suggestions on plugs?
    Jun 2007
    Perth
    Mines not a VR, but I just use champion or NGK plugs.
    Jul 2007
    Canberra
    NGK for sure
    Forever blowing bubbles.
    New Pollen Filter.
    You have to remove the black cover on the passenger side at the base of the windscreen to get to it.
    mk3 GTI 16v 3dr
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by bsting View Post
    New Pollen Filter.
    Also done already when the heatercore was replaced.
    Feb 2007
    Perth, WA
    Oil Filter = Genuine. Have read of many things going horribly wrong when you use a generic one. Horrid things like the whole engine dying. BAD. Dont risk it.
    Oil = I use Fuchs Titan Super GTO 10-40w, fully synthetic. Seems fine. There was Agip 10-60w full synthetic in the car when I got it. Seemed fine too.
    The fuchs (german!) is avail at my local supercheap. I think its only $40.
    Nothing else I can really help with sorry. If you can afford it, go Motul for any fluid, apparently its very very good stuff.
    Dec 2006
    Kilsyth, VIC
    wonder if I can get the genuine oil filter locally...
    We will see I suppose.
