Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 57
Thread: Servicing VR6
  1. #31
    Sep 2006
    From various things Ive read, Im thinking I might replace the O2 sensor. Only question is, do our cars run 1 or 2 sensors. I assume this is an OBDI and II thing, but am not sure what our cars are.
  2. #32
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by peedman View Post
    Hey if u can wait, this seems like a good deal: http://www.germanautoparts.com/Volks...ectrical/275/2
    Looks very interesting:
    Tune up kit, VR6 AAA Include STI performance wire set and 6 NGK BKR5EKU spark plugs. 105.00
    Ignition wire removal tool Ignition wire removal tool - Removes ignition wire from spark plug without pulling on cable. Professional quality metal tool designed to last, does not break like plastic versions. This tool is essential to remove ignition wires without damaging them. 43.00
    Oil filter kit Original equipment. Includes oil filter element and seal ring. Filter element has plastic ends. 10.92
    Fuel filter We recommend two new hose clamps shown below. 13.78
    Hose clamp, 13-14mm size range 2 required 0.71
    All of which comes to US$174.12 Which works out to be about AU$207 + shipping. At a guess I would say about US$30 for postage should cover it bringing the total to AU$243. (I have emailed them to ask about shipping).
    There would be a few questions first
    Are the all genuine OEM parts?
    Do you need the lead remover?
    I'd argue about the clamps, but at 71c...
    Considering I would be paying AU$153.78 to get the parts from Denlo and I wouldn't be getting the leads or removal tool it does sound like reasonable purchase. Just need to make up my mind if I want those leads or not. After all, if I don't change them out, it's somewhat easier and cheaper to buy in Australia. If I drop just the removal tool it brings it back to about AU$196 delivered, now that is VERY tempting... Wonder if leads will make it through the post...
  3. #33
    Oct 2006
    Yeh theyd be oem stuff.
  4. #34
    Dec 2006
    Kilsyth, VIC
    Quote Originally Posted by The_Hawk View Post
    Postage is actually $49 and makes the total US$223.12 or AU$268.06
    Using http://www.importpartsconnection.com/ for the same stuff, minus the tool (which I can't find) & postage, the total comes to US$166.96 so about the same at the end of the day.
    Arrrrrgggg, now I have to decide what to do. Do I just get the filters locally and do them now, or do a wait a little bit till I can afford to do the lot...
    It's definately worth it if I do the leads... That might be the go, save the tool, leads and plugs for a little later but do the fluids now.
  5. #35
    Aug 2007
    Camden, NSW
    I got my dad to make a tool for me. Cost nothing! There a threads on this forum on how to make one. It's not hard
    03 MkIV GTI - K04-001, APR 2.5" TBE/TIP/Software, Forge FMIC, GFB DV+, Powergasket+, Dark Tint, 17" Bora Sport, Bilstein shocks, Eibach springs, BMC CDA, Dieselgeek SS, Hella Celis, R32 Alloy Trim...
    95 MkIII VR6 (sold)
  6. #36
    Dec 2006
    Kilsyth, VIC
    If anyone is interested OEM Oil filter from McGrath Liverpool cost me $42.80
    But for the exciting part! I got a replacement trim part for the drivers side, side skirt that was missing! At $7 it has to be a contender for one of the cheapest parts for a VR6
  7. #37
    Sep 2006
    VR6 oil filters from Repco are like $28, and from MJM Autohaus (USA) you can get a pack of 5 OEM for about $60-70 including delivery.
  8. #38
    Dec 2006
    Kilsyth, VIC
    Yeah, I found OEM oil filters overseas for about US$11 each.
    As for the ones from Repco, they use Ryco filters, not the OEM Hengst ones which have been HIGHLY recommended.
    At the end of the day it was the only part I needed so although it was more expensive, it's all good... And I got the missing trim piece which makes me happy
  9. #39
    Dec 2006
    Kilsyth, VIC
    I have all the bits I need now, jacked the car up and had a brainwave...
    Thought I might have a quick bash at the oil filter housing before I drain all the oil. Seems multigrips really dont work and I'm going to need a 36mm spanner. Glad I found this out before I drained all the oil
    Problem is that no one seems to have a 36mm socket or ring spanner! Anyone know where I might find one?
    Bunnings are out, AutoBarn are out, Supercheap are out. And by out I mean they don't carry them.
    Lastly, anyone care to point out jack points on the Mk3 when using jack stands? I can jack the car up, but with only one jack point, where do you put the stand or where do you jack as an alternative?
  10. #40
    Dec 2006
    Kilsyth, VIC
    UPDATE!
    A mate assured me Supercheap had them since he was sitting watching Bathurst with two employees, so down I went and no they dont
    On the way home I stuck my head in AutoOne, the one place I hadn't thought about. The guy says no, but his other AutoOne 5 minutes down the road does... so at about 5 minutes to closing I got a 36mm 1/2 inch drive socket for $35
    Looks like the oil might be changed under lights, but at least it's still getting done today!
