i didnt get a word u just said lol but im interested!!!
well if its not rubbing on the gaurds then its not fat enough.
OT. as said allready there isnt much you can do without replacing somthing ie. suspention or wheels/tyres, but if you wanted to do somthing slightly dodgy to fix it ive got some extended bumpstops that you can put on that reduced shock travel with obviously means that the wheel wont go up into the gaurd enough to rub
just a thought
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
76 Scirocco
He meant removing the current bumpstops and putting in longer ones so you'll bottom out on them before you scrub your tyres. I wouldn't recommend that! Can get dangerous as suspension travel gives you control over your car. The ride will be pretty ****ty too if you keep bottoming out. I'd rather rub tyre than bottom out - I've shortened my bumpstops on my coilovers so the ride is a little more bearable.
eeek so what kind of springs can anyone suggest?
76 Scirocco
(]/_ O _____ O _\[)
"'(O8o)=\X/=(o8O)
[__|========|__]
