Results 1 to 10 of 18
Thread: Rough Idle mk3 golf 2.0 8v ady
    Oct 2016
    Central Coast, NSW
    As title says my golf has been running a little rough ever since I've owned it not exactly a problem but I'd rather it run smooth. Any help is appreciated.
    https://youtu.be/pJD3u2XvafU
    Sent from my ONEPLUS A3010 using Tapatalk
    Hyundai Getz (2015 -- 2017)
    Golf Mk3 GL 95' (2017 - 2018 - Now)
    Golf MK2 GTi 91' (2018 - Now)
    Nov 2015
    I am not a mechanic, but having owned a Mk3 for 20 years, a couple of things to try:
    - what fuel are you using? VWs drink premium unleaded (use the 95 RON as a minimum 98 RON is better if you can afford it, go with the reputable service stations, I find I get much better fuel economy from the Caltex Vortex premium 95 RON than the Shell stuff or the United stuff)
    - check the spark plugs and spark plug leads (if you are not getting a good spark in one or more cylinders then it will idle rough)
    - check you do not have a leak from the exhaust gas return pipe (On top of the silver rocker cover of the engine, there is a square black box on the left hand side, there is a two-pronged rubber pipe that leads in and out of it, check that rubber for cracks, unfortunately Mk3 have a lot of plastic/rubber pipework around engine and if you have a crack it will bleed air which may cause it to idle roughly)
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    Oct 2016
    Central Coast, NSW
    Checked my plugs recently and they were fine, distributor looked good too, will check exhaust leak, I run e10, I'll swap to 98 from now on.
    Thanks for the reply,
    Rohan.
    ECU relay (30?) goes bad somtimes and gives rough idle.
    Jan 2011
    Rooty Hill, Sydney
    Quote Originally Posted by Hodgey GTI View Post
    I don't think there's a single enthusiast on this forum who runs that shiit.
    U should just stick with what it says on the inside of the fuel flap!
    Oct 2016
    Central Coast, NSW
    Quote Originally Posted by KKK VR6 View Post
    When you say ****, you mean e10?
    Mar 2015
    Switch to 95 or 98, My 2.0 pinged BAD when I ran 91 for the first few weeks of ownership until I read the fuel filler cap. 95 or Above.
    Mk3 2.0. Mk3 VR6 CC. Future Mk2?
    Oct 2016
    Central Coast, NSW
    My filler cap says 91
    Nov 2015
    I understand that E10 has a RON of 94. All the Government advertising say that vehicles of Mk3 age can use E10 but that you should check with your manufacturer. However, I have never found anything official from VW which says the Mk3 can use E10. I believe that E10 will give you worse fuel economy too. 98 RON did not seem to make any significant difference to performance or fuel economy over 95 RON for me. I have run a tank of regular unleaded in my Mk3 in an emergency situation but it is definitely rough.
    Oct 2016
    Central Coast, NSW
    Just an update on my idle, I replaced my timing belt and it improved the idle a little bit but it's not perfect, when it's cold it sits at 1k dead till its warm and then goes back to bumping around 850-900. Going to try 95 fuel as my tank is near empty now.
    Thanks in advance,
    Rohan.
