vacuum servo/actuator mk3
Hi All,
the fresh air/recirculate flap that is worked by a vacuum servo/actuator is stuck in fresh air position. The button lights up
(slight humming sound) but the flap does not move. I checked all the hard plastic lines and there are no breaks. I'm not
sure about the layout under the dash and would like to ask first before poking around with an airbag near by.
Appreciate any fixes/replacement advice.
Thanks
- You may not post replies
- You may not edit your posts
Forum Rules
