![Support VWWC](https://www.vwwatercooled.com.au/forums/images/banners/supporters.gif)
Replacing door on Cabrio
Hi all
I need to replace a door on a Mk3 Cabrio. I can see that there are torx on the hinges and know I don't yet have the right size. There is limited space so I'm hoping someone can come up with an easy solution.
Will a bent 'allen type' key with a torx end be sufficient or will I need to get a socket?
I don't think there is room to get the ratchet in as well.
Also, what size. I'm thinking around T50 but could be wrong.
Any help is greatly appreciated.
cheers...doc
---------- Post added at 03:41 PM ---------- Previous post was at 01:42 PM ----------
Worked it out. It's a T45 and a bent 'allen key' style will do.
Yep T45. The right bit makes it so much easier. I spent ages trying to get a door off with alan keys and such and almost rounded the hole on one of the screws. Went and got a Kinchrome Torx bit set for like $20 and its been very useful. If you got it off without though, then don't worry about it. Haha
I haven't taken it off yet. I've just got a set of the kingchrome ones, then I realised the hinge comes apart if you undo the small bolt out the side. I'm such a dud. I've never had a car that has hinges like this. Hope I can loosen these bolts and just lift off the door. That would be much easier. As well, I haven't forgotten about the wires through the A pillar or the check strap. I'll just disconnect them first.
- You may not post replies
- You may not edit your posts
Forum Rules
