Results 1 to 3 of 3
Thread: Replacing door on Cabrio
    Apr 2008
    Bundoora Victoria
    Hi all
    I need to replace a door on a Mk3 Cabrio. I can see that there are torx on the hinges and know I don't yet have the right size. There is limited space so I'm hoping someone can come up with an easy solution.
    Will a bent 'allen type' key with a torx end be sufficient or will I need to get a socket?
    I don't think there is room to get the ratchet in as well.
    Also, what size. I'm thinking around T50 but could be wrong.
    Any help is greatly appreciated.
    cheers...doc
    ---------- Post added at 03:41 PM ---------- Previous post was at 01:42 PM ----------
    Worked it out. It's a T45 and a bent 'allen key' style will do.
    Sep 2009
    Yep T45. The right bit makes it so much easier. I spent ages trying to get a door off with alan keys and such and almost rounded the hole on one of the screws. Went and got a Kinchrome Torx bit set for like $20 and its been very useful. If you got it off without though, then don't worry about it. Haha
    Apr 2008
    Bundoora Victoria
    I haven't taken it off yet. I've just got a set of the kingchrome ones, then I realised the hinge comes apart if you undo the small bolt out the side. I'm such a dud. I've never had a car that has hinges like this. Hope I can loosen these bolts and just lift off the door. That would be much easier. As well, I haven't forgotten about the wires through the A pillar or the check strap. I'll just disconnect them first.
