Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Dash lights gone!
vr6mike Dash lights gone! 26-03-2008, 10:53 AM
DubSteve They are just lose mine are... 26-03-2008, 10:56 AM
vr6mike is it hard to get the cluster... 26-03-2008, 12:32 PM
Mrk_Mickey It's not hard. I'm not... 26-03-2008, 01:08 PM
DubSteve You have to take the light... 26-03-2008, 01:13 PM
Soundofav6 LOL...as I literally just... 26-03-2008, 01:17 PM
vr6mike thanks for the tips guys,... 26-03-2008, 02:04 PM
vr6mike thanks for the pics Hawk, can... 31-03-2008, 11:38 AM
wagits Actually no. There are two... 31-03-2008, 01:59 PM
vr6mike Thanks mate! should be able... 02-04-2008, 07:47 AM
vr6mike Fixed it up last night,... 05-04-2008, 09:06 AM
Pullstarter You in Canberra Mike? 05-04-2008, 11:05 AM
mk3pete i replaced mine with vl... 05-04-2008, 11:32 AM
vr6mike I was last weekend, but nah I... 08-04-2008, 02:24 PM
shammy hi 08-04-2008, 08:37 PM
Guest hey quick question... does... 19-07-2008, 12:50 AM
Mrk_Mickey Whilst i do like my green, i... 19-07-2008, 02:34 AM
The_Hawk OK, so more pictures will... 19-07-2008, 08:50 AM
Pullstarter Tamiya clear orange FTW!!... 19-07-2008, 10:44 AM
Guest Have u got a measurement for... 19-07-2008, 12:02 PM
    May 2007
    Kensington
    Dash lights gone!
    Have been driving around with only the tacho side dashlights working so have been guessing my speed but now the right hand side dashlight is out aswell so i'm in the dark! are these things easy to replace or is it hard to get the dash out to change the globes?
    Cheers,
    mike
    Sep 2006
    Australia?
    They are just lose mine are similar once in a while you actually have to pull the cluster out and tinker with the two bulbs up the top it happens!
    May 2007
    Kensington
    is it hard to get the cluster out?
    any tips?
    cheers
    Dec 2007
    Ermington, Sydney
    It's not hard. I'm not actually sure exactly HOW to do it, but I know it's not hard Does anyone know if there's any choice in bulb colour? I've been wondering if it was possible to change the colour
    Sep 2006
    Australia?
    You have to take the light switch on the right outand the airbag/abs plug out to. Get the screw behind there and then there are the screws in the right air vent to. There is also a click on the left hand side of the cluster that you need to take out to, in all there are 4 screws and then the plastic case comes out followed by the cluster and then there are just two bulbs up the top.
    You can change the colour but you then have to change the colours of the surrounding lights as they all light up green!
    LOL...as I literally just replaced mine a min ago than I see this post. I have been driving in pitch black for a week until now.
    it's not hard a 10 min job.
    Start from popping the air bag ABS plastic next to the sttering wheel with flat head.
    Pop out the head light switch unit. You push in with screw driver on the side from where the Air bag plastic use to be.
    Directly to the right of your to your radio, there is 2 piece of black plastic with a " half a bump" on each. also pop out with flat head.
    now you should see 2 screws on both side of the big plastic trim which hold the cluster in place, remove that.
    2 screws on both side of cluster, unscrew them.
    now you "flip" down the cluster. ( you will know what I mean when you get to here)
    Now you will be able to see the bulbs.
    P.S. TRUST ME ...USE your OEM screw driver, Otherwise you will surely loose drop the screw in the dash. NOT fun fishing it out !!!
    I got my bulbs from repco. I think I got ~20 cent change from 5 bucks for the 2 bulbs.
    May 2007
    Kensington
    thanks for the tips guys, will give it a shot when I get a chance and I know repco is open to buy the replacements, cheers again!
    Mar 2008
    You didnt by any chance note the part number for the globes. I also have one heater panel globe gone.
    May 2007
    Kensington
    thanks for the pics Hawk, can I ask which ones are the ones that illuminate the dash? u said the grey ones? in the pic they have been removed, I assume its from the middle up the top?
    cheers!
    Mar 2008
    Quote Originally Posted by vr6mike View Post
    cheers!
    Actually no. There are two gloves which light the guages. You do not need to unplug the cluster. Just unscrew the 2 screws on either side of the cluster, assuming you have taken the plastic surround off at this stage. I suggest using a magnetic screwdriver because you will (well I did) lose a screw down into the underpart of the dash. Once you have taken out those 2 screws grab the top of the cluster and bring it out towards you and down. On the top of the cluster you will see the 2 globes mounted on a white strip of plastic. If you cant undo them with your fingers (anti-clockwise) then use a pair of pincer pliers. Most of the time they are just loose or dirty and lose contact with the board. The part number is 47762 if the shop stocks NARVA items. I had to go to 3 auto places before I found them at an auto electrician.
    Hope this helps.
