Results 1 to 8 of 8
Thread: Recommendation on software for OBD2 diagnostics cable mk3 vr6 golf
    Mar 2007
    QLD
    Hi there All,
    Can anyone advise on where the name and a possible source for software to diagnose my Vr6 golf 95
    Hopefully something that is intuitive.
    Thanks is advance,
    Courtz
    Dec 2006
    Kilsyth, VIC
    Back in that era the computer is pretty basic so even then generic OBDII cables from ebay for under $10 using VAGCOM 409.1 in it's basic mode can read pretty much everything you need. For the investment it's a pretty good place to start.
    While a proper licensed Ross-Tech cable with VCDS would be ideal, it's far more expensive that you want to spend. As for intuitive... that's a different question.
    Mar 2007
    QLD
    Quote Originally Posted by The_Hawk View Post
    Thanks HAWK,
    The cable came with 409.11 and VCDS LITE now ON TO DECIPHER THE CODES.
    G70 open or short to plus (this is with my old MAF)
    G70 intermittent short to earth = - (new eurorevolotion supplied MAF)
    I suspect some wiring is a bit iffy somewhere.
    I feel more like a doctor now, the patient is telling me it's problems
    Dec 2006
    Kilsyth, VIC
    Ahhh VR6 wiring. I think I had that same error once upon a time!
    Mar 2007
    QLD
    Hi Hawk
    I am getting the same code with the MAF disconnected completely - does this definitely indicate that the wiring is the problem???
    G70 short to earth (29)
    Any help appreciated.
    Dec 2006
    Kilsyth, VIC
    Have you cleared the code each time?
    If it keeps coming back it does sound like it's a wiring problem.
    Mar 2007
    QLD
    It does come back after clearing, nearly instantly,
    there are 4 wires
    1 is earth
    1 is some signal to ecu to pin 17
    1 is some signal to ecu pin 16
    1 is some power
    I dont know which is which to troubleshoot.
    Arhhggg
    Jan 2016
    Georges Hall, NSW
    I would be checking the contacts on the cable to see if there is any damage or corrosion that might be messing around with the connection.
    VW MK2 Golf GTI 8V 1991
    VW MK3 Vento 1995 Daily Driver
