Results 1 to 5 of 5
Thread: WA- MK3 020 Transmission WANTED- Stuck in 3rd gear
    Feb 2015
    Kelmscott, WA
    Sooo I may have fallen victim to the dreaded 020 5spd Manual gearbox stuck in 3rd gear syndrome... Does anyone have a 5spd available for purchase here in WA, or failing that, is there someone that will swap/rebuild/sell me a trans for less than the $1320 + postage to get a box in from Washington?
    I appreciate ANY responses guys!
    Cheers,
    J-Mac
    Aug 2006
    Melbourne VIC
    Get in contact with Golfwagen in Perth.
    Jan 2010
    is it the syncro, or the gear linkage bushings? I lost some of the bushings due to a small water leak onto the rubbers which destroyed them, once replaced the gearbox was back to normal
    Feb 2015
    Kelmscott, WA
    I wish it was just the linkage. We had a crescent spanner on the actual lever on the box with a 3 foot pipe over the end and it still wasn't budging from 3rd. Clutch still operates normally so its not anything to do with the throw-out or anything. This is a pretty major f$ck-up in the German gearbox black magic department...
    Jan 2010
    The syncro must have gone, any "clunking" in the box? (caused by bits floating around in the oil?) Not sure if this would help, might be worth a try, go into the gearbox access port and see if you can see any bits in the oil - you may have to drain some oil to do this (its not easy to get back in either).
