Results 1 to 3 of 3
Thread: rear beam removed
    Aug 2011
    Westside bitches, Melbourne
    rear beam removed
    hey guys i got a little bit stuck on replacing the rear beam on the car..
    i got all the bolts undone and what not but now im stuck with the brake lines, if anyone has done this or can help me out and tell or link me to a page to remove the lines would be much appreciated.
    cheers ned
    -Silver 94 Golf mk3 R.I.P
    -mk4 GOLF 2L- daily&project
    "If I fitted 4x100 to 5x100 adapters and then a 5x100 to 5x112 adapters... would I die?"
    Gosford Central Coast NSW
    Hey mate, I've done it, not sure what your hung up on exactly?
    I think the easiest thing is probably to undo the lines at the bias block on the passenger side, leaving the lines attached to the beam.
    Also just undo the handbrake cables inside the cabin and let them pull out of the guide tubes.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Nov 2005
    Sydney NSW
    I did a rear end beam swap long time ago.
    undo all you can from the beam while it is still attached to the car by the 6 main bolts.
    if you need more room undo the rear suspention lower bolt so that it drops the axels lower.
    the rear axel is heavy. support it before you drop the 6 main bolts. i did it by my self with a small tv trolley and some jack stands on the axels.
    Make sure that when you put it back together that you align the axels evenly. you don't want to be crabbing down the road.
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
