no one has suggested checking ignition timing ? Some Golf 3's you can change timing slightly .
Also what about checking the knock sensor itself ???? It could be giving an incorrect signal to the ecu which in turn controls the mapping for timing !
Another thing to check would be the air intake temp sensor on the airbox .
Fuel could be another issue , fuel pressure ok ? fuel pressure under load ok ? injectors blocked ?
So many things to check before de-carbonising the head !
