Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 95
Thread: Rattle under load when engine is hot
  1. #81
    Sep 2006
    Australia?
  2. #82
    Nov 2008
    Hi sydVR6
    VAG Showing no codes.
    I have been running 98 octane fuel, with an additional octane booster... I think this has a major improvement, but still not enough...
    Injectors and head have been cleaned with Petroject machine. I also decarbed the head a few times myself..
    I have been using all sorts of injector cleaners products....
    no luck.
    I cannot see any clear way to tell how effective the knock sensor is with VAGCOM.... I guess it is working as i usually have reduced performance when the engine is really hot...(retarded timing)...
    Mk3 2.0 8v Injected AGG
  3. #83
    Apr 2006
    VW Race HQ - Sydney
    how about posting some logs ?
    Injector duty cycle and lambda values as well as ignition timing and intake air temp ?
  4. #84
    How tight is the bolt on the knock sensor? I forget the setting but it's only like 10-15 lbs.
  5. #85
    Nov 2008
    Hi Bugracer - please check out post 42 of this thread... I have attached logs there.
    If you need more data I would be happy to log some more... just let me know what you need.
    H100vw - yep, the Knock Sensor is set correctly at 15 foot pounds of torque.
  6. #86
    Apr 2006
    VW Race HQ - Sydney
    Quote Originally Posted by jmystaki View Post
    Ive gone through the logs and they arent very helpful .
    there is only one time where you actually go above 2000rpm , and the intervals are like almost 5 seconds apart !
    When you log an old car you can only do 1 channel at a time so you can keep the frame rate above 1.1-1.2 . Do those same channels again , this time logging 1 at a time !
    (why do I get the feeling no-one else knows how to read logs???)
  7. #87
    Well, I'm going to throw something new into the mix here.
    A non-functioning EGR valve could be causing your ping problem. You could check that the valve opens properly and the ports under the valve are clear.
    Bit of an explanation here;
    http://autorepair.about.com/od/gloss..._egr-valve.htm
    I don't think this has been suggested yet and I've seen blocked EGR valves cause similar problems on a few Jap cars, so worth maybe looking at...
    http://www.cardomain.com/id/sydvr6
    Subaru WRX Wagon 06 + Peugeot 306 GTi6
  8. #88
    Apr 2006
    VW Race HQ - Sydney
    MK3 doesnt have EGR valve as far as I know .
    Quote Originally Posted by sydVR6 View Post
  9. #89
    I know the VR6 does. I'm pretty sure the 2.0 does (without the Bentley manual in front of me) but could be wrong.
    GAP stocks them for the 8v:
    http://www.germanautoparts.com/Volks...f/Engine/317/1
  10. #90
    Apr 2006
    VW Race HQ - Sydney
    Show us a picture , Ive never seen one on a Australian VR6
    US cars are different to ours dont forget
