Results 1 to 10 of 10
Thread: Random plug in engine bay
    Sep 2006
    West Sydney
    I'm sorting out the wiring under the bonnet at the moment and came across this female-end plug not connected to anything:
    It's a pretty unique connector - the crimps inside it are perpendicular to each other. Pretty much all other plugs in the engine bay have the crimps sitting on the same axis. That said, I can't seem to find the male-end connector for it.
    The plug's attached to a bracket that also holds the hose for the water squirters (also seen in pic). I'm just wondering if it does anything and if I actually need it or not?
    TIA.
    Sep 2006
    West Sydney
    Heated washers mate.
    Goes live when you use the squirters.
    So it warms the water when it passes through the hosing? Guess I don't need it then! Thanks Gavin.
    Quote Originally Posted by rayray086 View Post
    Unless you move to Victoria, it's probably not required
    Camden, Sydney
    Yeah its not used Ray.
    Does that mean you might be able to drive your car again soon??
    Aug 2006
    Melbourne VIC
    I thought it was for the genuine led light for under the bonnet.
    Sep 2006
    West Sydney
    Quote Originally Posted by Water Boy View Post
    I suppose you can use it for such a thing - the wires are just a positive 12V and a negative ground right? Just have to chop that module off.
    Neons in engine bay
    Edit: Just had a thought about it. The light would only come on when you use the squirters
    Jun 2007
    Eastern Suburbs Melbourne
    that could scare the sheet out of you at night, if you weren't 100% concentrating and had a bright enough light!
    i like volkswagens
    Aug 2006
    Melbourne VIC
    Mine has a little switch.
    Jun 2009
    Auckland, New Zealand
    I've seen that plug lying around in my engine bay as well, it just chills under the rain tray from memory?
    2016 Golf Alltrack
    Previous:
    Mk3 1.8t
