Results 1 to 7 of 7
Thread: radiator fan temps
    ventogirl Guest
    radiator fan temps
    Hi guys,
    I have a 1996 Vento 2L and I was wondering if anyone had the thermo fan cut-in/cut-out temperatures (including the high speed fans)?
    Thanks!
    You have a Vento... Sweet !!
    Don't think I have welcomed you here.. Welcome aboard.
    By the way, your real helps are coming But I think the fan cut in at the 80s*C range.
    ventogirl Guest
    Quote Originally Posted by Soundofav6 View Post
    Thanks nice forum you guys have here.
    Its gotta be alot higher than 80 tho. Normal operating temp is 90
    I remember Golf Loon say to me normal range for vr6 is about 90ish to 100 something and 2.0 is lower, or maybe he was talking about the oil temperature?? I always get confused with the oil and water temperature
    Someone help please.
    Jul 2007
    Constitution Hill
    the cut in temp for the 2.0 is:
    low speed off 84-91 C; on at 92-97 C
    high speed off 91-98 C; on at 99-105 C
    ventogirl Guest
    Quote Originally Posted by cOS View Post
    cool! thank you!
    Dec 2006
    Kilsyth, VIC
    What about for the VR6?
    I assume they are pretty close to that. My high speed is shagged and stays on permanently, so I have a hard switch in the high speed line, so if I ever fix the problem I just leave the switch on (or remove it) and it will work as it's intended.
    Problem is my low speed is now coming on all the time too, then staying on for a few minutes after the car has stopped, even if I cold start it and move it 5 feet.
    Still working on what is causing that.
