Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: R32 or r36 Engine Conversion idea
    Nov 2010
    sunshine,vic
    This is just an idea after i saw a youtube video when some German put a r36 dsg into a mk3. I was just wondering how difficult it would be to bolt a r32 or a r36 engine in a mk3 and if its possible to make it manual ? not really sure if they even come in manual. Would you need custom engine mounts , drive shafts , gearbox adaptor, wiring issues + costs
    94' Golf Mk3 Vr6
    Sep 2009
    I don't think the r32 swap is overly difficult, think the r36 is much harder though. As you wont be running the awd I think you'd need to bolt it up to a fwd transmission anyway so I think you would definitely make it manual.
    I've never seriously looked into the r32 swap but have read things about it a while ago, really can't remember though. Hopefully one of the people who've seriously considered it (and I know there is atleast a couple on here that have got as far as sourcing the engine, but never finished it off) can give some actually helpful information
    Jun 2011
    It bolts directly in.
    You can use your vr6 o2a trans clutch and flywheel. Either standalone or some
    Stock ecu wizardry.
    Nov 2010
    sunshine,vic
    Stock ecu wizardry.
    yea i was just reading that on vwvortex . i dont think i have the time and money to strip down the car . plus i would have to wait for someone to crash their passat and it wont be cheap maybe look into it in the future .it would be so cool to have a r36 mk3 though .
    94' Golf Mk3 Vr6
    Jun 2011
    R32 would be enough IMHO.
    As Ben said I think there's physical fitment issues with the 3.6
    You can get the swap done for 5k.
    Engine, exhaust, ecu and gearbox mods.
    Nov 2010
    sunshine,vic
    okay so that means i shouldnt have a problem with my driveshafts if i bolted up my o2A into the r32 ? i actually rather swap the r32 and turbo instead of turboing the vr6 2.8 i know it would cost more but i want to build it as a 1/4mile and a daily at the same time.
    94' Golf Mk3 Vr6
    Sep 2009
    They should just bolt up I'm fairly sure. If you're confident in doing work yourself, an r32 swap will probably make a much faster car then you would make from spending the same amount of money on modifying the 12v 2.8 VR6. Do a few little simple bolt on mods to the r32 and you'd have one hell of a quick little car that would probably destroy most of the heavily worked 2.8 vr6's out there. The most complicated thing will probably be all the electrical stuff, it would probably be easiest to run it on standalone. Mechanically it should just bolt in.
    Nov 2010
    sunshine,vic
    Quote Originally Posted by Ben J View Post
    I havent really seen a vr6 on the street yet except car meets ! and ive also heard that you would have to get the key coded is that true ?
    94' Golf Mk3 Vr6
    Jun 2011
    You would send the ecu to storm in the uk to get de-immobilized. Standalone is where it's at but. I have a megasquirt 3x with a r32 tune loaded if you actually I through with it. Standalone means you'll break 200fwkw straight away.
    It is mechanically bolt in. I've had the block mated to my o2a with a autotech lightweight flywheel an vr6 clutch. Get a stage 2 or something a bit better then oem.
    The front engine mount you need an 18mm washer underneath to lift it up. If you have motor mount spacers you'll be right for the washer.
    Jun 2011
    Also the throttle body is a problem. As its dbw.
    I have the Nissan q45 which bolts up to the stock manifold (i think) it might be a 2mm off or something ridiculous. In which case wobble bolts or an adapter.
