Results 1 to 7 of 7
Thread: Question re: water temp on a VR6
    Jun 2013
    Leichhardt, NSW
    Hi all, i'm sure that this has been asked a 100 times before. What are the correct parramaters for water temp in a VR6? As an example, should water temp needle always be sitting at 90 (middle) and constantly sit there like a BMW does (regardless of wheather and driving conditions) or does it fluctuate depending on wheather, driving conditions, etc.?
    My understanding is that fan also comes on bewteen 90ish - 100 degrees?
    any insight is much appreciated,
    Aug 2008
    Rowville, VIC
    nfi. but mines ALWAYS been in the middle once I hit op temp.
    if it were any different (in my car) I'd be a little concerned.
    Jun 2013
    Leichhardt, NSW
    Quote Originally Posted by decksla View Post
    Do you find that it drops much or pretty much is there all the time?
    Aug 2008
    Rowville, VIC
    mine is all the time once it's at temperate.
    this is all daily driving mind you and your results may vary if you track it or thrash it for a long time.
    Jun 2013
    Leichhardt, NSW
    OK, i find mine is always fluctuating between 80 -90c. can go up depending on driving and temp outside etc, but just want sure. Back in a VW after 12 years of driving bm's and im use to how they operate for obvious reasons. Guess i just being paranoid as im use the Bm's now.. rain hail, shine, putting around or thrashing... sits on 1/2 and never moves..
    Mar 2013
    deloraine tasmania
    Mine always sits about the same, with in a 10 degree range and I am happy with that. Your sounds about right too. Yes, my fan comes on about 100 and off again once it gets below 95.
    Jun 2013
    Leichhardt, NSW
    Cheers danwatto
