Results 1 to 10 of 15
Thread: Problems connecting to ECU
    Mar 2014
    Bundoora, Victoria
    Unhappy Problems connecting to ECU
    I bought one of those bluetooth OBD readers online. Plugged it in, connected to my tablet. No problems. On the adapter status though it says no connection to ECU. How can I fix this?
    Is it because I have an aftermarket stereo? I tried disconnecting it and trying to connect to the ECU, same deal.
    Would really like to get this to work.
    Past - '95 VW Golf MK3 VR6
    Mar 2014
    Bundoora, Victoria
    Anyone?
    Might just give it a pass then.
    Oct 2012
    Just get a $15 cord and download the free software and use a laptop. maybe the connector doesnt work with the OBD1 cars?
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by mb1907953 View Post
    OBD1? I wasn't sure if it were an ODB1 or ODB2, the adapter I have is for ODB2, would explain it.
    Which one should I get? There are plenty on eBay and I just want to make sure I get the right one.
    Mar 2012
    Central Coast, NSW
    Obd1 reads fine.
    You need to have your accessories on for it to work. So if you didn't have the key in and accessories on that would explain it.
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by anthony--t View Post
    Obd1 reads fine.
    I've even tried with the car running and no luck.
    Mar 2012
    Central Coast, NSW
    Hmmm. What software? I just use a free version of vcds and an eBay cable. Always worked for me.
    Mar 2014
    Bundoora, Victoria
    ELM327 v1.5 with the Torque app (paid) running on Android. I've seen other places suggesting to test the voltage between pins 4 and 7 and see if it's under 9V. Mine's slightly above 9V but I don't think that should make much difference.
    I did have a cable left over when I was wiring up the stereo so maybe that's it? The cable was originally hooked up the the stock stereo.
    Mar 2014
    Bundoora, Victoria
    A bit of an update. I purchased a VAG-COM KKL 409 type cable and still issues. I can hear some relay making a clicking sound.
    I realised though that my car was manufactured in 1995 which means I probably have OBD1, so no dice.
    Not too fussed about it since the onboard computer shows enough on the instrument cluster to keep me satisfied.
    Mar 2012
    Central Coast, NSW
    I think it's just the software you're using. I have a cable and free version of vagcom which use to work fine for me on my 1994 vr6
